For RADIUS authentication of a NEAP host MAC address, the switch generates a <user name, password> pair as described in the following list:
Important
Important
Use the following Global Configuration examples to select a password format that combines one or more of these three elements:
  • Padding enabled , password = 010010011253..05. (when the switch IP address and port are used).
  • Padding enabled, password = 010010011253… (when only the switch IP address is used).
  • No padding (default option). Password = 000011220001 (when only the user‘s MAC address is used).
The following example illustrates the <user name, password> pair format with no padding enabled and using the IP address, MAC address, and key-string as the password.
switch IP address = 192.0.2.5
non-EAP host MAC address = 00 C0 C1 C2 C3 C4
port = 25
Key-String = abcdef
  • user name = 00C0C1C2C3C4
  • password = 010010011253.00C0C1C2C3C4.25.abcdef
Use the command show eapol system to verify the formatting.
Switch:1>show eapol system
                                  Eapol System
                      eap : enabled
            Eapol Version : 3
          non-eap-pwd-fmt : mac-addr
      non-eap-pwd-fmt key : ******
  non-eap-pwd-fmt padding : disabled
  auto-isid-offset status : disabled
   auto-isid-offset value : 15980000
